Marine Chrysler 360 trouble
J
James Morris
Guest
"Hi--
I am having trouble w
"Hi--
I am having trouble with one of my engines. The starboard engine when run at high RPM's (3000) after about a minute or so begins missing and will eventually cut off if let run. After slowing down, it sometimes clears up but sometimes will continue to run rough. I have put on a new coil, capacitor, and fuel pump. I am looking for any ideas what might be causing this. Please send any ideas to [email protected]
Thanks in advance,
James"
" James, try checking your pi
" James, try checking your pick up tube in your fuel tank. Debris can build up and will pinch off the flow. Had a similar problem several years ago. "
" James,
I had a similar is
" James,
I had a similar issue a year or so ago. It turned out to be water in the gas tank. I installed a water seperating filter system and have been perfect since.
Dean "
