Alarm 90 hp johnson 1993
rmike72pu
"when i start engine with muff
"when i start engine with mufflers , runs rough 1-2 minutes , smooths out , 3- 4 minutes alarm goes off ( constant ) water from engine is warm , block is hot , what is going on"
"That model running on a flush
"That model running on a flushette, the water must be turned on full blast. Sounds like the water pump requiires replacing."
92 90hp johnson has rattle com
92 90hp johnson has rattle coming fron engine when reved up 3000 to 4000 rpm can you tell what it could be.sounds like lose starter but cna't pin it down thanks for any info.
