1978 Evinrude Hard Cold Start
eric_g
New boat owner. Manual on orde
New boat owner. Manual on order. Having problems or not sure of proper cold start procedures. First time starting takes a long time. Once started no problems unless sits for 1-2 hours then same problem. Motor cranks fast.
Eric
"how do i wire a guest battery
"how do i wire a guest battery switch , what is field wire , where is regulator .Or do I just wire from where it comes off of motor to switch"
"90HP johnson motor when runni
"90HP johnson motor when running with mufflers, water running out of pee port ,warm , alarm goes off after 3-5 minutes , whats up ?"
Michael.... Go to previous pag
Michael.... Go to previous page. Click on "Start New Discussion" in blue border.. Re-enter your question.
"Eric, I don't have a manu
"Eric, I don't have a manual that cover your motor so when you get yours follow the procedure for checking the choke to be sure it is operating correctly. I am assuming that you are moumping the primer bulb until firm before starting."
Yes using the primer bulb. Wil
Yes using the primer bulb. Will check out the chock procedures when I have my manual.
Thanks Ibnfishn
