"I HAVE TAKEN A AQ140 CAM AND
"I HAVE TAKEN A AQ140 CAM AND STUCK IT INTO A AQ125A MOTOR, LARGER BORE. WITH A LARGER CAM AND I AM GOING TO RUN DUAL CARBS, WHICH SHOULD NET ME MORE POWER, I HOPE! I NEED TO KNOW IF THE FLYWHEELS ARE THE SAME, THE 125 HAS A BALANCER, WHERE AS THE AQ 140 HAS A PULLEY ON THE CRANK. DOES THIS MEAN THAT ONE IS EXTERNALLY BALANCED AND THE OTHER IS INTERNALLY. OR DOES IT MAKE A DIFFERENCE WITH THE FLYWHEELS?"
