Results 1 to 3 of 3
  1. #1
    Join Date
    Jul 2007
    Location
    Posts
    376
    Default For some reason my fuel inject
    For some reason my fuel injectors stopped getting fuel. i was checking the usual parts when i noticed that the fuel filter was out of gas. filled it up with gas then the engine came back to like. after a few minutes it went out again. i checked the fuel filter again; it was empty once again. i've been doing some reading about the issue and i'm going to check the pickup and anti siphon valve for debris or clogs. my question is how did you guys do yours and how often should i do this?
    Bass Slayer: 1990 Tracker Deep V 16
    40 hp Johnson- TJ40ELESR
    Blue Water Led Bow and Deck lighting
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,238
    Default "At the top of your Fuel Tank
    "At the top of your Fuel Tank is the Outlet Fitting,......
    Remove it,....
    You might find the Pick-up Tube to be your Problem,.....
    Or the Anti-Siphon Valve is the Hose Barb coming Out of the elbow.......
    It needs Cleaning whenever there's Crap from the Tank plugging it........."
  3. #3
    Join Date
    Nov 2002
    Location
    Mullica Hill, New Jersey, United States
    Posts
    1,810
    Default Just don't forget to reins
    Just don't forget to reinstall it when you are through. It is a vital part of your safety equipment and is required by the Coast Guard.
Similar Threads
  1. As anyone heard of a Wizzard ?????
    By grasshopper in forum Identifying Model / Year / Horsepower
    Last Post: 01-01-2011, 10:04 PM
  2. Ever heard of this
    By corsair23 in forum OMC Sterndrive and Inboard Archive
    Last Post: 05-10-2009, 10:29 PM
  3. Anyone heard of this suggestion
    By bzvw3l in forum Mercury Mariner Outboard Archive
    Last Post: 04-10-2009, 04:35 PM
  4. 1988 50 OMC Cobra Antisiphon Valve
    By matthew in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-22-2007, 07:03 PM
  5. OMC Oldboys Ever Heard of This
    By greaseball04 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-06-2007, 08:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
