Results 1 to 12 of 12
Thread: Steering
  1. #1
    Default "I need advice on what type of
    "I need advice on what type of Teleflex steering to buy. I have a 19 ft boat with a 140HP outboard.The steering froze up and I am looking at a teleflex ss132, ss137 or ss147, do I need the no feedback?"
  2. #2
    Join Date
    May 2006
    Location
    pensacola, fl., u.s.a.
    Posts
    1,366
    Default 132/137 are 3.0 turns lock to
    132/137 are 3.0 turns lock to lock. both are rated for your power. the 147 is rated higher hp. 4.2 turns. (less effort) any would work. the 132 (nfb) would be more comfortable than the 137. the 147 is probably overkill on your boat.(and slower handling)
  3. #3
    Default Thank you for the info. I thin
    Thank you for the info. I think I will go with the 132.
  4. #4
    Default I managed to get the old telef
    I managed to get the old teleflex cable out and the new one in. The new one is 3 feet longer than the old one-what do I do with the extra?
  5. #5
    Join Date
    May 2006
    Location
    Posts
    1,366
    Default not enough to loop. can you sn
    not enough to loop. can you snake it up and down along the side?
  6. #6
    Default "Turns out the new one was 5 f
    "Turns out the new one was 5 feet longer, I looped it inside the center console and it seems to work fine.
    Next time I will measure the old one instead of relying on another's "I'm sure it will fit your boat""
  7. #7
    Join Date
    May 2006
    Location
    Posts
    1,366
    Default part of the part number printe
    part of the part number printed on the cable is the length in inches.
  8. #8
    Default "I could not read the numbers
    "I could not read the numbers on the old one and I had to order the new one. Live and learn!
    Thanks for the help. The one I ordered was 18 feet, I measured the old one and it was 13 feet.
    It's hard to believe one of these can freeze up like that.
    Now that I have a new one in, besides greasing at the tilt tube what else should I do to maintain this cable?"
  9. #9
    Join Date
    May 2006
    Location
    Posts
    1,366
    Default turn it hard to port when sitt
    turn it hard to port when sitting. keep the slide out of the elements.
  10. #10
    Join Date
    May 2006
    Location
    Posts
    1,366
    Default and happy boating. S.
  11. #11
    Default "The steering works fine when
    "The steering works fine when not moving, once the boat is moving the steering pretty much stays where you put it and steers hard. I tried trimming the motor up and down and it did not help. All grease fittings have fresh grease."
  12. #12
    Join Date
    Oct 2007
    Location
    Macclesfield, NC, USA
    Posts
    1
    Default "NEED HELP!! I have a 1985 bl
    "NEED HELP!! I have a 1985 bluewater that I cannot seem to get the upper helm station to work. I think it is air in the system, but it will not bleed out. Any help would be nice. It has a teleflex steering system with a helm pump at upper and lower stations."
Similar Threads
  1. Steering
    By radar11 in forum Chrysler Force Outboard Forum
    Last Post: 09-26-2009, 03:45 PM
  2. Steering mod
    By hying000 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-04-2009, 05:52 AM
  3. Steering
    By popo in forum Mercruiser Sterndrive Archive
    Last Post: 03-11-2009, 09:52 AM
  4. Help with steering
    By jeff6898 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-05-2008, 02:31 PM
  5. Need Help with steering please
    By polyian in forum Mercruiser Sterndrive Archive
    Last Post: 11-16-2007, 12:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
