MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 10 of 10
  1. #1
    Join Date
    Aug 2007
    Location
    Charleston, SC, USA
    Posts
    6
    Default I am borrowing a friend's
    I am borrowing a friend's 2005 Merc 5 HP outboard and want to get the gas and oil mixture correct. The serial number is OT881050. The model number is ME 5M. Can you help
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,114
    Default "Ken, I'm thinking that th
    "Ken, I'm thinking that this motor should be a 4 stroke - so nothing to mix..."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Join Date
    Aug 2007
    Location
    Charleston, SC, USA
    Posts
    6
    Default "The owner said it was a mix a
    "The owner said it was a mix and advised me to ask my marine pump juckey what the mix should be. I thoughtt that was unreliable advice so I searched online and found you to be the best resource. The engines manual is not online, nor do I have time to order it. The engine is also very poorly described, as neither a four stroke or two stroke. Now what do you think? Ken"
  4. #4
    Join Date
    May 2007
    Location
    Posts
    9,114
    Default "Ken, with that serial number
    "Ken, with that serial number it has to be a 4 stroke - Merc hasn't built a 2 stroke, 5 horse (which would required mixed gas) anytime in the past 20 years.
    Should just take straight gas...."
    Graham
  5. #5
    Join Date
    May 2007
    Location
    Posts
    9,114
    Default "Sorry, should restate that la
    "Sorry, should restate that last post - haven't built a 5 horse 2 stroke in North America in more like 10 years although Merc in Belgium still produces them. But their serials would be 0Pxxxxx"
    Graham
  6. #6
    Default They most certainly do make 2-
    They most certainly do make 2-stroke 5hp Mercury O/B's.
    They are "technically" mercury but they sure say it.They have 5.0 on the back and have built-in tanks.They run 50:1 but you can lean it out a bit more.
    My buddy has a 2003 mercury 5hp 2-stroke.
    It's pretty easy to tell if it is a 2 or 4 stroke...take the hood off and look at the motor.The 2-stroke will have a basic cylinder head and spark plug...the 4 stroke will a valve cover and a side mount spark plug.Plus the 4 stroke will have a noticeble oil dipstick for checking the oil level....2 strokes use the pre-mix to lube the cylinders.
  7. #7
    Join Date
    Aug 2007
    Location
    Charleston, SC, USA
    Posts
    6
    Default "Terry, Thank you. I will forw
    "Terry, Thank you. I will forward this information to the the boat/engine owner. Regards, Ken"
  8. #8
    Tony Hill's Avatar
    Tony Hill Guest
    Default "I have a 2001 5HP engine, and
    "I have a 2001 5HP engine, and I'm positive they still make them. 50:1 mix works well."
  9. #9
    miguel torres's Avatar
    miguel torres Guest
    Default i have a mariner 4hp # a890355
    i have a mariner 4hp # a890355 what year is it.
  10. #10
    Join Date
    May 2007
    Location
    Posts
    9,114
    Default "Miguel, that is a 1992 Mercur
    "Miguel, that is a 1992 Mercury built Mariner.."
    Graham
Similar Threads
  1. oil fuel mixture - 1978 Merc 150 hp
    By aquaholictom in forum Fuel Gas Oil Mixture Ratio
    Last Post: 06-26-2010, 09:07 AM
  2. OilFuel mixture and the type of oil for 36 merc
    By Ryan Cartwright in forum Mercury Mariner Outboard Archive
    Last Post: 04-26-2008, 02:32 PM
  3. Merc Mariner Black Max 150 HP oil mixture
    By jammer25 in forum Mercury Mariner Outboard Archive
    Last Post: 06-20-2007, 11:48 AM
  4. Fuel mixture for Merc 75 ob motor
    By rtdewey in forum Mercury Mariner Outboard Archive
    Last Post: 03-21-2006, 09:27 PM
  5. 1975 Merc 650 oilfuel mixture
    By Mark Richards in forum Outboard motors archive 2000-2004
    Last Post: 05-22-2002, 04:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
