MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 6 of 6
  1. #1
    L. Marquith's Avatar
    L. Marquith Guest
    Default " I bought a 1983 40 hp Mercur
    " I bought a 1983 40 hp Mercury late in season this year. The question I have is this. When you choke it and turn over it turns over way to slow almost like your battery is dead. When it fires but is not running it turns over alot easier. I was wondering if anyone ever experienced this problem. It almost seems to me like a car engine when the timing is to far advanced and you turn it over warm. It will start but turn over very slow. Is it possible that the timing is off, starter problem, or any other ideas. Thanks for any advice or knowledge anyone has.Oh it is a model 1402T 1983 40 hp Merc. "
  2. #2
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,308
    Default "Mercurys are not my line of e
    "Mercurys are not my line of expertise but your problem is a common one that could be attributed to any engine.
    Since the engine does turn over normally at times, you can pretty well assume that the starter is okay (hopefully).
    Usually that type problem is contributed to a slightly loose battery cable, or tight but dirty cable connection, or a cable that is corroded within the insulation somewhere.
    After the engine has been turning over slowly for a few seconds, check by hand for a overly warm or hot cable. A hot cable will lead you to a faulty connection quite quickly.
    This type problem could be at the battery, starter solenoid, the gound cable conection, or even at the starter.
    It's unlikely that the timing is any part of the problem. If it was, the engine should kick back, firing against itself. Let us know what you find.
    Joe[img][/img]"
    We occasionally have questions. If you fail to answer, it may affect ours.
  3. #3
    L. Marquith Guest
    Default " Joe, I have the boat in the
    " Joe, I have the boat in the garage for storage for the winter, but I will check those items out when possible. I see you are on here alot so you should be easy to reply to. Perhaps after these holidays are over I can do some checks on the cables and connections without turning the boat over. Would it hurt to turn it over a bit without fuel in it just to check or will I damage any seals or anything? Thanks. "
  4. #4
    Join Date
    Feb 2001
    Location
    Posts
    14,308
    Default "There would be enough lubrica
    "There would be enough lubrication within the crankcase whereas you could crank it over without doing any damage. However, it would be a good idea to take the plug wires off of the spark plugs just in case..... you don't want it to actually start and run. Tonyob is the Mercury guru but he's been pretty tied up with a business venture lately. Perhaps he'll be jumping in here later on.
    Joe[img][/img]"
  5. #5
    L.Marquith's Avatar
    L.Marquith Guest
    Default " Hey thanks.Like I say I will
    " Hey thanks.Like I say I will probably venture into this when the holidays are over but am thankful for any advice. I am fairly mechanically inclined with most gas engines(cars ,lawn mowers) but will take any advice I can get on outboards. Happy holidays. "
  6. #6
    MercuryDude's Avatar
    MercuryDude Guest
    Default " While you are checking it, c
    " While you are checking it, check your starter solenoid. It may be going bad. It will work correctly when the engine is cold, but the added load of a warm engine may make it drag. Try all of Joe's checks first and then check the soledoid. Good luck and have fun on the water. "
Similar Threads
  1. Starter Help 50 hp mercury 1983 50 hp
    By JBAuch in forum Mercury Mariner Outboard Forum
    Last Post: 03-28-2010, 06:49 PM
  2. Starter mercury 50 hp
    By ts7424 in forum Mercury Mariner Outboard Archive
    Last Post: 10-26-2009, 07:40 PM
  3. 1984 35 HP Mercury Starter Problem
    By bc98usa in forum Mercury Mariner Outboard Archive
    Last Post: 04-16-2008, 08:51 AM
  4. Starter problem
    By manrod111 in forum Johnson Evinrude Outboard Archive
    Last Post: 11-20-2007, 06:38 AM
  5. Mercury 110 Starter
    By ndauby in forum Mercury Mariner Outboard Archive
    Last Post: 04-15-2006, 10:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
