C
clayag05
Guest
" I have a 1964 Chrysler West
" I have a 1964 Chrysler West Bend Outboard(6HP, Model #6401) with a Tillotson carb. I am having some trouble with my engine running at high speeds. Here is a scenario to help explain my question: When I am on the lake with the throttle at full speed, the motor seems to be holding back. When I am traveling full throttle and I disconnect the fuel line, the motor will continue to "hold off" for a few seconds and then the motor will rev. up and operate like its supposed to until the gas runs out of the carb. What kind of problem do I have and how do it fix it? Is it just simply adjusting the Hi speed mixture screw? If so, does anyone have a link to a diagram that shows which adjustment screw is the hi speed adjustment for this style carb? Thanks. "
