"I RECENTLY BOUGHT A 1972 115
"I RECENTLY BOUGHT A 1972 115 (1150) MERC, I CHANGED THE WATER PUMP, CLEANED ALL WATER LINES SINCE I HAD NO FLOW OUT THE (PEE HOLE). AFTER INSTALLING IT ON MY BOAT AND GETTING IT ON THE WATER NOW I HAVE NO POWER. THE ENGINE JUST DOSENT PUSH RIGHT AT FIRST LIKE IT SHOULD, IT TAKES AROUND 30 SECONDS TO A MINUTE JUST TO GET THE BOAT TO PLANE. AT FIRST THOUGHT I HAD A CARB PROBLEM WHICH I STILL MIGHT, BUT I HAVE RUN A TANK OF GAS TREATED WITH SEA FOAM THROUGH THE MOTOR AND ITS RUNNING BETTER THAN IT DID AT FIRST, BUT WHAT COULD THE PROBLEM BE?"
