C
chris bruscato
Guest
" my oil warning light is blin
" my oil warning light is blinking and the motor won't rev over 1500 rpms. everything is fine at low rpms. i tried to reset the low oil warning switch but its fine.i know its getting oil due to the blue smoke when i flushed the motor.my oil psi guage is very low 1-2 psi.what is the normal operating range it should be in? i suspect the pump is bad or hopefully just some blockage somewhere. any fix tricks are appreciated,greatly. "
