Results 1 to 3 of 3
  1. #1
    Default "Hi - my Bayliner has a 2.3 li
    "Hi - my Bayliner has a 2.3 liter Ford engine. It was fully serviced professionally a few months ago and has run really well until today. (I had cooling probs with it but they have been resolved). The engine started with no problem and ran for a full hour with no problem. Then the problem began. It would only idle. Try the throttle and it cut out. Checked the plugs which were sooted-up, cleaned them and it ran not too bad but the same problem appeared again. Engine has been left standing for a good 2 months but has been started up every now and then, most parts replaced on it including water-pump, coil, water jackets (jackets replaced after the full service). Can anyone cast some light on this one for me or is this a problem common with this engine? Any help appreciated. Thanks. JIM"
  2. #2
    Eddie from Oregon's Avatar
    Eddie from Oregon Guest
    Default What year? Is it points and co
    What year? Is it points and condenser or breakerless electronic ignition?
  3. #3
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    Default could be carb not adjusted rig
    could be carb not adjusted right also
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
Similar Threads
  1. 23 liter ford
    By sonnyp in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-31-2009, 08:42 PM
  2. 23 liter OMC Ford
    By ebbtide88 in forum OMC Sterndrive and Inboard Forum
    Last Post: 07-01-2009, 06:50 AM
  3. 23 liter ford omc
    By nathanmi in forum OMC Sterndrive and Inboard Archive
    Last Post: 05-01-2009, 08:04 AM
  4. Ford 23 Liter IO
    By masterc143 in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 04-20-2009, 06:22 PM
  5. Omc manifold for 23 liter ford
    By michael keeney in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-29-2008, 07:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
