"I am looking for a fix for my
"I am looking for a fix for my 2006 60 HP Mercury outboard. The engine only has about 20 hours on it, in it's second season. Just recently I have noticed a lot of gas leaking from the vent hose that is connected to the fuel pump (slilver box on left side of engine, if standing behind it). This hose is connected to the top of the fuel pump and feeds down to the bottom of the engine casing where it vents out. The gas drips more at idle speed than high speed.
Any thoughts?
Is my fuel pressure too high? There is a pressure valve on the fuel pump, if you release it while the engine is running quite a bit of fuel will shoot out. Is that normal?
Brad"
Any thoughts?
Brad"
