Page 1 of 6 123 ... LastLast
Results 1 to 30 of 153
  1. #1
    Mike Evans's Avatar
    Mike Evans Guest
    Default "I inherited a Montgomery Ward
    "I inherited a Montgomery Ward Sea King 7hp outboard Clinton Engine Corporation Model k700 2106A Serial 742688 Type 60 27407R. Any idea of date of manufacture (pre or post 1969)? Please respond to [email protected]"
  2. #2
    Default "my name is glenn my mate hase
    "my name is glenn my mate hase a 115 hp outbord evinrude 1969 mod i dont know a thing about outbords it gos good when it gets hot it wont start after it get swicth off it gos when it cools it got a new pump in it and pumps good do you know what could be the prublem thanks [email protected]"
  3. #3
    Join Date
    Oct 2000
    Location
    Posts
    109
    Default "Does anyone know if you can s
    "Does anyone know if you can still get parts for a Montgomery Ward Sea King 7hp. Model:K7002107A, serial #: 647946, type: 6027370R, manufactured by Clinton Engine Corporation? Please respond to: [email protected]"
  4. #4
    Stan Kalenda's Avatar
    Stan Kalenda Guest
    Default "Have a Clinton engine 7.5hp.
    "Have a Clinton engine 7.5hp. - runs good but prop doesn't turn when in gear. Sounds like maybe a shirr pin or gear is stripped? Any ideas?
    and how to fix this?
    Please reply to: [email protected]
    Thanks!!"
  5. #5
    Ray Brown's Avatar
    Ray Brown Guest
    Default " Have a Wards Sea King/Clinto
    " Have a Wards Sea King/Clinton Model# XTV.52329A, S/N 1602954, Type# 900-7106A. Could anyone tell me the year and horse power. Thank you. "
  6. #6
    Thomas Campbell's Avatar
    Thomas Campbell Guest
    Default "I have a Montgomery Ward moto
    "I have a Montgomery Ward motor with the following info:
    model: k500 31080
    serial: 1051747
    type: XIV 52250
    Could anyone give me the model year and hp size for the motor? Thanks, please email any info to [email protected]"
  7. #7
    jeff melhus's Avatar
    jeff melhus Guest
    Default I have a montgomery wards sea
    I have a montgomery wards sea king / clinton outboard model #k200 3106a. it is 2hp. can anyone tell me the right spark plug for this motor?
  8. #8
    jeff melhus Guest
    Default "i have a 2hp sea king made by
    "i have a 2hp sea king made by clinton engines. model#K200 3106A. serial#951386. type#xtv52202. can anyone tell me the correct spark plug for this motor, along with year,fuel mixture & any other info? thanx"
  9. #9
    Josh K's Avatar
    Josh K Guest
    Default I inheritaed an 7 horse Montgo
    I inheritaed an 7 horse Montgomery Ward Sea King model # K700 1107A Type 27270 R is there any idea of a manufacture date and anywhere i can get original parts?
  10. #10
    Stephen K. Linn's Avatar
    Stephen K. Linn Guest
    Default I just bought a Wards Sea King
    I just bought a Wards Sea King 3.5 HP outboard motor manufactured by Clinton Motors Corp. The model # is K350 5106 A. Can enyone tell me where I can find out when it was built and how I can get an owner's manual and a service manual? Thank You.
    Stephen
  11. #11
    Robi's Avatar
    Robi Guest
    Default "I have a 7hp Sea King mdl #K7
    "I have a 7hp Sea King mdl #K7002107A Ser #657337, I am looking for an exhaust gasket. Does anyone know where I can find parts?"
  12. #12
    Jac Jepson's Avatar
    Jac Jepson Guest
    Default I have a Wards Sea King (C
    I have a Wards Sea King (Clinton Engine) 9 horse outboard; looking for a fuel pump.
  13. #13
    michael picklesimer's Avatar
    michael picklesimer Guest
    Default I have a 7hp sea king model K7
    I have a 7hp sea king model K700 type 6027370r looking for air filter assembly and possibly more.
  14. #14
    DJ Patterson's Avatar
    DJ Patterson Guest
    Default My father-in-law has a Clinton
    My father-in-law has a Clinton Outboard that was his fathers. He would like to see if it runs but is uncertain of the gas/oil mix. Can anyone help? The model and serial number are J9 1101 0
    Ser. # 101123
  15. #15
    jimRudnick's Avatar
    jimRudnick Guest
    Default A J9 Clinton takes a 32:1 mixt
    A J9 Clinton takes a 32:1 mixture. 4 OZ to 1 gallon.
  16. #16
    ken cox's Avatar
    ken cox Guest
    Default do you know the year of a seak
    do you know the year of a seaking 7.5 hp model vwr52179a
  17. #17
    Patrick Jacobson's Avatar
    Patrick Jacobson Guest
    Default Looking for a Walbro LMB-179-1
    Looking for a Walbro LMB-179-1 carb for my Wards Sea King/Clinton air cooled 7.5 hp outboard. Any help is much appreciated! Thanks!
  18. #18
    Bob Grenier's Avatar
    Bob Grenier Guest
    Default "I just inherited a 3.5 hp out
    "I just inherited a 3.5 hp outboard motor. Bad news is it's previous owner painted the cover and I can't read what button and knob does what. This thing runs, but I'm not sure if it's air cooled, and or if it's an oil/gas mix or what. I can figure out most of this by trial & error but I'd like to know if I can come up with an owner's manual for this motor. It's model number is K350 4000A--sn is 70476. Would like to know the year of this thing and whom it was made for Sears/Wards??? Can anyone help?"
  19. #19
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,130
    Default "Bob, you should have started
    "Bob, you should have started a new discussion - you almost got lost here.
    Anyhow, you have a Clinton 3.5 horse Air-Cooled model built somewhere between 1976-80.
    You can mix 2 cycle engine oil (for lawnmowers/chainsaws - NOT Marine oil) at a ratio of 24:1 with regular unleaded gas and it will run fine for you.
    Clinton went bankrupt a couple of times over the years and finally completely called it quits in 1980 - so the records are a little scarce and I can't narrow down your model any closer than above.
    Because it has a Clinton model number (as opposed to a Sears or Wards) it may simply have been marketed as a Clinton engine.
    You can most likely find a manual at www.discount-marine-parts.com just email them with your model number and I'm sure they can hook you up..."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  20. #20
    Richard E Miller's Avatar
    Richard E Miller Guest
    Default "Do you have any idea where I
    "Do you have any idea where I can find parts for a Clinton motor, model # J7001102B. Please e-mail me back at [email protected]"
  21. #21
    Mike Blevins's Avatar
    Mike Blevins Guest
    Default "hi my grandfather past recent
    "hi my grandfather past recently got a 7.0 hp motor model# k-700 1107 A Serial# 593208,from his house and I can pull the cord so not locked up I hope anyway, what kind of gas mixture do I use in it, }and how can I get a manuel so I can try to fix it up and get it running"
  22. #22
    Join Date
    Oct 2007
    Location
    Sanford, Florida, Seminole
    Posts
    1
    Default Hey i have a 9Hp Clinton Che
    Hey
    i have a 9Hp Clinton Cheif and i have no idea when it was manufactured. Model no: K900 5101 C.
    Serial no:1410195.
  23. #23
    Robert May's Avatar
    Robert May Guest
    Default "I have a Clinton Engines Corp
    "I have a Clinton Engines Corp. outboard motor, Model No. K300 3106A, Serial No. 940554, Type No. XTV 52203. Can anyone tell me when it was made, what the fuel mixture should be, what type of spark plug to use, and ony other owner information. Please respond to [email protected]. Thank you."
  24. #24
    Join Date
    May 2007
    Location
    Posts
    9,130
    Default "Robert, I believe your type i
    "Robert, I believe your type is actually KTV (probably obscured a bit).
    Your motor is a 1975, single cylinder, 3 horse, built by Clinton for Montgomery Wards (store brand).
    The fuel mixes at 24:1 - regular unleaded gas and 2 cycle engine oil such as used for lawnmowers and chainsaws - NOT marine oil.
    You can use an NGK BM4A spark plug gapped at .030" (or a Champion cross ref to that NGK)."
    Graham
  25. #25
    Robert May's Avatar
    Robert May Guest
    Default "Graham, thanks for the inform
    "Graham, thanks for the information. Would this motor be air cooled or water cooled. It has cooling fins to make me think it is air cooled but it also looks like it has a water intake hole also."
  26. #26
    Join Date
    May 2007
    Location
    Posts
    9,130
    Default "Robert, yes it's air cool
    "Robert, yes it's air cooled. The exhaust housing/lower unit were common to a number of outboard mfg's - so water cooled so it was built to accomodate both..."
    Graham
  27. #27
    BucSloan's Avatar
    BucSloan Guest
    Default "I have just got a clinton out
    "I have just got a clinton outboard but know nothing about it; Manufacture date, Hp rateing, fuel mix, where to get parts or if I can, any info would help
    Model no. K7515106 B
    Serial no. 1382891
    Type No. XTV 50575 B"
  28. #28
    Join Date
    May 2007
    Location
    Posts
    9,130
    Default "Your type is actually KTV 505
    "Your type is actually KTV 50575 B - they must have printed the "K" poorly, because many list it that way.
    Your Clinton was built by them for Mongomery Wards and sold under the store brand "Sea King".
    It is a 1978 (clinton model K751), single cylinder, 7.5 horse.
    The few clinton's that I have seen are air-cooled engines and I have no information that they ever produced a water-cooled model (but can't say for sure).
    If your motor is air cooled you can mix it with regular unleaded gas and 2 cycle oil (such as used for lawnmowers/chainsaws) - not marine oil at a ratio of 24:1.
    Both Clinton and Montgomery Wards are out of business so certain parts may be hard to find. There is a number of sources on the internet that can provide you with tune-up/ignition parts or alternately, a local small engine shop may be able to help you out since the carbs, point etc were of a fairly generic variety..."
    Graham
  29. #29
    Join Date
    Jan 2008
    Location
    Scottsboro, Alabama, USA
    Posts
    2
    Default "I purchased a Clinton Sea Kin
    "I purchased a Clinton Sea King outboard. 4 HP Model # K4002106A--Serial No. 681380--Type No. 60-27404R
    It runs, but not well. In the carb. bowel was the seat for the carb. needle. I have 24:1 chainsaw oil in the gas. I have ordered from Dave Henshaw a manuel but have not received it as yet. Do you know what year it was built and can I seat the needle sleeve with the needle valve?"
  30. #30
    Join Date
    Jan 2008
    Location
    Posts
    2
    Default "To edit my email from 1-11-08
    "To edit my email from 1-11-08 09:44 pm, after looking at the carb again the brass seat was not from the needle valve. Could not even get to the bowl. Don't know where it came from! I am a woodworker and not a mechanic. Any help would be much appreciated. I also have more numbers from the carb but don't know if they mean anything. Thank you for any help you can give me."
Similar Threads
  1. Clinton j9 5hp outboard
    By old_evinrdues in forum Clinton Outboards
    Last Post: 03-24-2010, 10:20 AM
  2. CLINTON OUTBOARD
    By coler0kw in forum Clinton Outboards
    Last Post: 04-20-2009, 07:58 PM
  3. Clinton outboard
    By Robert May in forum Clinton Outboards
    Last Post: 03-21-2009, 07:23 PM
  4. Clinton Beaver 75 hp outboard
    By tom_sata in forum Archive 2003-2009
    Last Post: 03-24-2007, 06:13 PM
  5. Small Clinton outboard
    By Erik Lowell in forum Archive 2003-2009
    Last Post: 09-13-2006, 03:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
