R
Ryan A
Guest
"I have a 4.3L AlphaOne stern
"I have a 4.3L AlphaOne stern drive, 1990. For the first minute or so after starting, there is an obvious squeeling noise that sounds like belts or pulleys. However, puttering at low speed for a minute or so makes it go away. Then I can drive as much as I want noise-free. However, if I turn it off for a while, and restart (even with engine still hot), the noise is back for about a minute or less.
I noticed the other day that the belt to the alternator is a bit looser than the other belt. It appears that there is a "slide" tension that can easily be adjusted by loosening one bolt and pivoting the alternator away from the belt, therefore tightening it. Is it really that simple? Does it sound like this could eliminate the squeeling problem?"
