50 GL back firing
pablo
"the engine has been intermitt
"the engine has been intermittently backfiring. typically, this occurs after idling a while. Any suggestions?
Paul"
"Cleant he connections in the
"Cleant he connections in the ignition coil. You seem to have a common problem with the wrong tacho readings, and it is probably due to faulty/rusty/wet connections at the ignition coil."
