Electric fuel pump
dcso408
if i wanted to install an elec
if i wanted to install an electric fuel pump and use mix on my 89 110vro what size should use 2-3.5 or 3-5 psi? i have an in the floor tank should i install it in between the tank check and the bulb or after the bulb?
thanks
ted
"Are you talking about an elec
"Are you talking about an electric primer pump in lieu of the primer ball? If so, I think OMC only made one type. If you are talking about using an automotive type, the answer to your question is that you should not install it anywhere on the boat at all."
Just get a pump from say a 79
Just get a pump from say a 79 V-4 and the spot to install it is on your intake manifold.Just look you will see the plug ( for pulsing ) and the 2 holes to mount the pump.
79- 83 V-4 or even the newer 8
79- 83 V-4 or even the newer 88 HP "special" motors.
