"I have a AQ125A in a 19ft Bay
"I have a AQ125A in a 19ft Bayliner, what my problem is that i was on the river and everything was running fine, then there was a loud bang and then i dead in the water. The boat still turns over, it is getting fuel however when i tried to start it, it was backfiring through the carb. I have been told that it might be something with the timing. I recently put electronic ignition in it also. I now have the front end off the motor exposing the timing belt but do not see anything obvoius. Also which is number one piston when looking at the engine from in the boat?? Any help would be apprecitated.
Thank You"
Thank You"
