"What a great board, can't
"What a great board, can't believe I found it. I need help. I would normally use a mechanic but Katrina took out most shops and nearly all good mechanics. They are running six to eight weeks backlog so I would like to try fixing this myself. I have a 1998 Robalo 1920 with Mercury 150XL carb (same year) less than 100 hours on motor. Model # 1-150422UD serial 0G594613. Here is problem. Took boat out ran fine coming back in it took several attempts to get it to plane out but it eventually did. I suspected fuel so I bypassed main and used 6 gal tank. Boat ran perfect. I know it doesn't sound like a charging issue yet. After replacing fuel lines and filters I ran it and it ran perfect. Next trip same issue upon return so I replace primer bulb. Ran perfect on test. Last trip boat ran perfect on the way out but when I tried to change locations it wouldn't plane again. After it eventually planed (and ran perfectly) I returned to the dock and when I tried to start the motor the battery was completely dead. I recharged and it held charge. I now suspect the motor only runs poorly after heating up. I suspect stator? maybe regulator/rectifier? only failing after heating up? No, the tachometer is not erratic. I am no mechanic but I have decent tools a digital multi-meter and the shop manual (athough it is very confusing with so many different models covered). I searched the posts so I have a little understanding of the charging/electrical system and I downloaded the DVA movie and will watch it next. Anyone want to help a novice along the way? Where would you start? Any special tools I will need? Merc stator is part#398-96-10A19 so I think it is an integral 40 amp system.
Ron"
Ron"
