MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Default i'm wondering what it woul
    i'm wondering what it would cost to rebuild a 97 mercury 500 50hp motor...i'm thinking about buying a boat and the seller has stated the motor has low compression in cyl.1 also says may need a water impeller?
  2. #2
    not-a-student's Avatar
    not-a-student Guest
    Default "Very hard to say. It depends
    "Very hard to say. It depends on whether you go to a big dealer with high overhead or a small independent shop.Labour varies from $40 to $100 an hour.Parts is another matter ,new parts are expensive and used parts for a 97 may be hard to find it all depends on where you are.If you post where you live someone might steer you to a good shop."
  3. #3
    Default "thx for your response,$40-$10
    "thx for your response,$40-$100 sounds about right from what ive gathered.just wonder about how many hrs. on average a job like this would take"
  4. #4
    chk's Avatar
    chk Guest
    Default What are you going to re-build
    What are you going to re-build Using USED parts ?
Similar Threads
  1. 50hp Mercury Blue Rebuild Question
    By Smokey228 in forum Mercury Mariner Outboard Forum
    Last Post: 09-13-2010, 12:16 PM
  2. Mercury Mariner 50HP engine rebuild problems
    By arfon in forum Mercury Mariner Outboard Archive
    Last Post: 07-17-2009, 08:27 AM
  3. Carb rebuild 50HP johnson
    By andy_75 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-28-2009, 07:26 PM
  4. b83 50hp 4cyl OB carb ID and rebuild
    By al billings in forum Mercury Mariner Outboard Archive
    Last Post: 04-05-2007, 04:39 PM
  5. b86 50hp Johnson VRO rebuild
    By Steve W in forum Johnson Evinrude Outboard Archive
    Last Post: 09-11-2006, 09:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
