" Where is the cavitation plat
" Where is the cavitation plate (the plate just above the prop) in relation to the keel (bottom of the boat at the transom)?
If anything was wrong within the lower unit, it wouldn't slip. It would either do nothing at all (no movement) or it would be jumping in and out of gear which would give you the sensation of hitting a object in the water... a clunking, jerking sensation.
You really haven't defined what you mean by "slipping". The term of "slipping" usually pertains to having the prop hub slip within the prop. If this was the case, the slippage would be worse at the higher rpms, not better.
Joe (30+ Years With OMC) "
