470 water in exhaust
nsfireman
Before replacing the sterndriv
Before replacing the sterndrive impeller when I would run it on a hose there was water coming out with the exhaust. Now with the new impeller I ran it on a garden hose and there is no water coming out with the exhaust. Is this normal.
"As long as there was plenty o
"As long as there was plenty of water exiting at the bottom of the outdrive, it is normal. Generally, a small amount of water or water vapor will exit thru the prop hub while on a hose and muffs while the majority will dump out of the bottom of the OD water outlets."
