Results 1 to 5 of 5
  1. #1
    Dan D.'s Avatar
    Dan D. Guest
    Default "I have a 1975, 70hp Johnson o
    "I have a 1975, 70hp Johnson outboard, model #70ESL75E and serial #14285352. I've searched and searched for the tech specs for this motor but no luck. I want to sell it and would like to be able to give potential buyers more info than..."Yeah, it runs". Even a website sugg. would be great! Thanks for the help."
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    8,980
    Default "Dan, what exactly are you aft
    "Dan, what exactly are you after - I can look up things like what is the recommended plugs/gap, wide open rpm range etc.
    If you could give an idea of what you are after maybe we can help you out a bit..."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Dan D.'s Avatar
    Dan D. Guest
    Default "Thanks for responding, Graham
    "Thanks for responding, Graham. Sorry I wasn't specific before! Here's what I'm really looking for...
    -2 stroke or 4 stroke(buddy sugg. it might be 4 stroke)? -Oil injected? -WOT RPM range?
    -Torque est.? -For selling it...What's a reasonable minimum price I should ask for if it's in "good" running condition with "fair" apperance? I am utterly clueless. Thanks for helping a newbie!"
  4. #4
    Join Date
    May 2007
    Location
    Posts
    8,980
    Default "Dan, it will be a 2 stroke, n
    "Dan, it will be a 2 stroke, not injected (unless it had an aftermarket add-on), so will require mixed gas (50:1).
    Although the motor is a little over 30 years old as long as it is in reasonable cosmetic shape for it's age, that's fine (some scratches etc).
    A potential buyer will want to know if it's running? or when was it last run.
    The biggest question usually is "what's the compression". If you don't know, have it tested (or borrow a tester and check it yourself).
    If the compression is good, the motor runs and it looks relatively "pretty" you can look to get between 500 - 750 bucks for it depending on where you are (what kind of market exists for this horsepower).
    A 70 horse could be considered to be in the upper end of "mid-horsepower" engines. Too big for most utility boats, but in the range for fiberglass runabouts and pontoon boats - so again depends on your "market"..."
    Graham
  5. #5
    Dan D.'s Avatar
    Dan D. Guest
    Default Thanks Graham! I can't th
    Thanks Graham! I can't thank you enough for taking the time to answer my questions. This info. will be extremely helpful.
Similar Threads
  1. BMW D12 Tech Specs
    By Brent Tyler in forum BMW
    Last Post: 09-12-2011, 07:05 PM
  2. 1975 Johnson 70hp
    By RKM in forum Johnson Evinrude Outboard Forum
    Last Post: 08-13-2010, 11:51 PM
  3. 1975 70hp Johnson
    By nailbag in forum Johnson Evinrude Outboard Archive
    Last Post: 11-23-2009, 07:15 PM
  4. 1975 70hp specs
    By fordtrckman in forum Johnson Evinrude Outboard Archive
    Last Post: 12-22-2008, 02:20 PM
  5. Johnson 70hp sea horse 1975
    By roly in forum Johnson Evinrude Outboard Archive
    Last Post: 11-08-2006, 01:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
