"The motor was having trouble
"The motor was having trouble idling and I checked fuel, air, plugs, wires and found #3 cylinder had no compression and the others had around 110. removed that head and no seal leaks were found. Found the rings were stuck but cylinder not scratched. Used carb cleaner and got them unstuck. Replaced head. Motor ran good until 2 weeks later. My son said it was knocking pretty bad and idled back to landing. Oil was ok, #3 no compression again. Took off belt to be sure nothing external was bad - no luck there. Took both heads off and all looks ok. Rotated crank and pistons move ok and cannot feel any backlash when pressing on each piston. Any thoughts on this?"
