Yamaha 50HP 2 stroke
A
Anhony Davies
Guest
"I enter my Webster Cat in tim
"I enter my Webster Cat in time trials similar to car rallies but at sea, we have to keep to a no,inated soeed between markers I am finding that my engine picks up on its own accord throttle forward and off it goes slight back throttle down it goes trying to keep it at the nominated speed on 12 knots is alomost impssible pleas help"
"Surging, is usually caused by
"Surging, is usually caused by a fouled carb(s) - when was it last cleaned???"
Hi Graham
The last time the
Hi Graham
The last time the carbi was cleaned was 6 weekd ago during the 100 hour service.
Thanks for help
Anthony
"Did the surging start after i
"Did the surging start after it was cleaned? If yes, it sounds like some gunk in the jet was missed or the jet itself was damaged..."
"Hi Graham
Thanks for your
"Hi Graham
Thanks for your suggestion before the surging started I would just drive the boat as a constant speed did not matter so I did not notcie the surge so much now the speed has to be constant I have to try and control it as precise as I can , you go to 10 knots but it keeps going up, not in high revs then you just throttle e touch and it drops of to 5 knots then you have to throttle up again.
Regards
Anthony"
