I have a 1986 260 hp mercruise
I have a 1986 260 hp mercruiser. I recently replaced the starter and now the volt meter reads between 10.5 and 11.5 reguardless of the engine rpms. Also the tach doesn't read the true rpm's all the time it will red line for a while then drop to zero then bounce around for a while maybe stop at the true rpm's then start the bouncing around again. The tach did this before the starter was changed.
Also at times there would be a whine coming from the alternator and the volts would jump up to 18 volts.
I changed the alternator this past weekend thinking this would solve the problems and it did eliminate the whine but the volts are still low.
Could I have a loose ground somewhere or maybe the voltage regulator gone bad.
I also replaced the batteries this year not because of the problems they were 4 years old and I don't want them to fail while I'm out fishing. 200 dollars every 4 or so years is cheaper then a tow.
