71_avenger
"I just bought my 1971 Cee Bee
"I just bought my 1971 Cee Bee Avenger with the original engine '71 Merc 800 from the original owner - my friend. He serviced the motor well. He had just replaced all the fuel lines and filter last season. I just put in new plugs. Couple of days ago we were running on the lake full throttle and the boat worked great then hit a few large wakes/waves and then the engine started to fail. It would run and then get weak, I'd give it more throttle it would die. I managed to bring it in to shore on a slow pace. The lower end is smooth, no drag, fresh fluid end of last season. It pumps water just fine. Not knowing what caused it to run poorly, I replaced the 5 year old plugs. Let the engine sit out in the hot sun for 2 days to make sure plug wires and everything is dry - took it out on the lake again and it still won't run right. Only other thing I know I messed with is that round knob on the control box - I don't know what it does, but I turned it a few times both directions and seemed to do nothing at the time, but maybe it is the cause of the motor not running now?
I am totally new to this web site and came across this thread because I need some advice - what do you guys think? My guess is there is something out of adjustment, maybe the waves knocked something loose or stuck? Could the motor have gotten wet? It dried out for 2 days, new plugs - still nothing."
