el_pescador
Silver Medal Contributor
"Chris, first thing I would do
"Chris, first thing I would do is to make sure that the throttle cable is secured to the block,and observe what is happening at the carb linkage when you try to give throttle (is it moving, or...?). If all OK, then I would remove the crankshaft pulley and verify that the three marks on the timing gears are where they should be. If the marks are where they should be, then I would check that the ignition timing is 6º BTDC at idle and 32-36º at 4,200 RPM. If OK, then I would have a look at the carb accelerator pump."
