"Can someone help me diagnose
"Can someone help me diagnose my problem? I have received a low oil pressure alarm on 2 occasions. Both have been on very high temperature days (>105*F air temp), and both after skiing/wakeboarding (so the oil is hot), then idling in gear. On each occasion the problem it always at idle, and is intermittant. This makes me suspect a bad oil pressure sensor, but I'd like other opinions.
Here's what I know: The boat is a 2001 Four Winns 180 with the Volvo-Penta 4.3GL sterndrive; ~200hrs. Oil and filter are changed annually - by me. The first time this happened, I was concerned that it was my selection of an automotive oil (Mobil 1 10w30), so I changed it to the Volvo-Penta 30wt synthetic. (Oil level is within the hashmarks on the dipstick) That appeared to have fixed it, at least until the next 100*+ outing over the weekend.
So I looked closely at the guages to see what was happening. When the ignition is turned on, all of the guage needles sweep the guages, then return to zero - except the oil pressure, it stays put. Then when I start the motor, the oil pressure jumps around a bit, then settles in at or near the red (there are no numbers on my guages.) Sometimes I get an audible alarm, and the oil light. When I put it in gear and rev the engine, the oil pressure quickly moves to the mid-point on the guage, and the alarm and oil light go out. When back to idling, the problem does not always return, but the pressure seems to be consistently near the red.
I'm a reasonable automotive mechanic, and have a Clymer's manual for the boat (which I haven't yet consulted for this problem.) Any suggestions?"
