Results 1 to 5 of 5
  1. #1
    BRRRR_In_NJ's Avatar
    BRRRR_In_NJ Guest
    Default OK it's late in the seaso
    OK it's late in the season and time to put the boat away. Please let me know what the proper procedure would be for winterizing a 1991 115hp Rude VRO. I have added Gas Stabilizer to the gas the last 2 times out as weather has kept me ashore more often than I have wanted. Do I need to drain the carbs or run the engine till they are dry (pull the gas line on final engine flush). What's the procedure for Fogging? What about draining water from lower unit-water pump? Will simply tilting the engine several times eliminate the excess water? I want to get this right.
  2. #2
    Join Date
    Nov 2005
    Location
    Posts
    89
    Default 135 merc peeing
    135 merc peeing
  3. #3
    Join Date
    Jul 2002
    Location
    Posts
    92
    Default "Brrrr Go to the following
    "Brrrr
    Go to the following link, they talk in detail about winterizing all types on marine engines.
    http://www.dolphinmarineservice.homestead.com/Wint.html
    dennis"
  4. #4
    Join Date
    Jul 2002
    Location
    Posts
    92
    Default " Brrrr Go to the following
    " Brrrr
    Go to the following link, they talk in detail about winterizing all types of marine engins.
    dennis "
  5. #5
    BRRRR_in_NJ's Avatar
    BRRRR_in_NJ Guest
    Default Dennis These are very comp
    Dennis
    These are very complete instructions for winterizing engine.
    Thanks!
    BRRR
Similar Threads
  1. Winterizing Merc MCM 898 questions
    By wish2fish in forum Mercruiser Sterndrive Forum
    Last Post: 11-10-2009, 07:54 AM
  2. Winterizing a 350 mag mpi mie
    By srdancer90 in forum Mercruiser Sterndrive Forum
    Last Post: 10-04-2009, 10:42 AM
  3. Winterizing
    By rcaponeg in forum Mercruiser Sterndrive Archive
    Last Post: 11-11-2007, 05:28 PM
  4. Help winterizing 89 350
    By steve smith in forum Volvo Penta Gas Archive
    Last Post: 11-16-2005, 10:38 PM
  5. Outboard winterizing questions
    By MIKEPAUL in forum Outboard motors archive 2000-2004
    Last Post: 01-06-2002, 01:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
