Click for Crusader parts and manuals!
Results 1 to 3 of 3
  1. #1
    Default "I am looking at a boat powere
    "I am looking at a boat powered with twin 1996 Crusader 350 XL engines with aprox 800 fresh water hours. As I plan to use the boat for offshore trips of 50 mi or more, I would like to get some info on what I should replace, change, upgrade to achive the highest reliability possible. Risers are first on my list.......
    Thanks in advance!
  2. #2
    Join Date
    Nov 2002
    Location
    Mullica Hill, New Jersey, United States
    Posts
    1,810
    Default "I would certainly change all
    "I would certainly change all fluids and filters. I would then look at all belts, hoses and ignition components. I would also remove and inspect the risers, installing new gaskets when reassembling.
    In addition to this list, I would inspect the entire fuel and exhaust systems, looking for failed clamps, leaks, and aging hoses. I would check all of the mounting hardware and control fasteners. Finally, I would check the engine alignment.
    These are items which should be checked on a very regular basis, but since most people do not properly maintain their boats, I would certainly give special attention to them prior to putting my family at risk.
    Good luck
    Rick"
  3. #3
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,554
    Default "Be sure to have spare for EVE
    "Be sure to have spare for EVERY critical component on the engines: belts, impellers, hoses, fuel filters, etc.
    JEff"
Similar Threads
  1. Crusader Model 1996 350 Identification... help please
    By Eric.C in forum Crusader Marine Engine Forum
    Last Post: 11-01-2010, 11:23 PM
  2. 74 XLS 1996 Crusader
    By jtorretto in forum Crusader Marine Engine Forum
    Last Post: 11-16-2009, 08:43 AM
  3. Twin Crusader 454bs 1984Couple of questions
    By nightstalker in forum Crusader Marine Archive
    Last Post: 07-12-2009, 06:17 PM
  4. 1996 Crusader 454xli
    By lmmi in forum Crusader Marine Archive
    Last Post: 04-02-2009, 08:43 AM
  5. Crusader 454 XLI 1996 Spark retard error
    By tellefson in forum Crusader Marine Archive
    Last Post: 10-14-2008, 07:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
