Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 4 of 4
  1. #1
    Default "I have a 1987 I believe 125hp
    "I have a 1987 I believe 125hp force engine. First question is how many rpm's should the engine normally go up too. Mine just barely reaches 6000 rpm's. Also when it is fully throttled it kicks back and does not run properly any ideas as to what is going on would be greatly appreciated. [img][/img]"
  2. #2
    Join Date
    May 2007
    Posts
    9,267
    Default "Joshua, your max rpms should
    "Joshua, your max rpms should only be 5250 - so if she is cranking up near 6 grand it is no wonder she is kicking back on you. You are lucky that it hasn't thrown a rod..."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Default Thanks for the info. So is it
    Thanks for the info. So is it normal for a 125 h.p. engine on a 17.5 ft larson open bow to only go 30 mph. and should I adjust the throttle as well? Thanks again
  4. #4
    Join Date
    May 2007
    Posts
    9,267
    Default "Is it "normal" - what
    "Is it "normal" - what's normal - how much does the boat weigh? what's the total load with pasengers etc? those will contribute to top speed or lack of it..
    Also, if this is hitting almost 6 grand in rpms, you are way under propped - you could up your pitch by 5", get down to where you should be for rpms and be pushing that much more water increasing your top speed in the process - probably about another 10 mph.
    Properly propped you should be getting in the 36-40mph range with that set-up depending on your load and weight distribution onboard..."
    Graham
Similar Threads
  1. 1997 4.3 L engine quits (sometimes) with fast full throttle
    By tundrarules in forum Mercruiser Sterndrive Forum
    Last Post: 07-09-2010, 08:29 PM
  2. Engine races uncontrolled at full throttle
    By Steve Dixon in forum Mercruiser Sterndrive Archive
    Last Post: 07-17-2008, 11:06 PM
  3. Engine bogs down under full throttle
    By 86fourwinns in forum Mercruiser Sterndrive Archive
    Last Post: 06-18-2008, 12:28 AM
  4. 23 sputters at full throttle when engine is hot
    By rexo910 in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-29-2007, 02:35 PM
  5. 1988 yammaha150 kicks back or backfires at idle
    By nelson in forum Outboard motors archive 2000-2004
    Last Post: 01-14-2003, 11:03 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
