37L closed cooling system
nsfireman
I have a 3.7L 470 I/O that is
I have a 3.7L 470 I/O that is overheating. I have ordered a new impeller for the sterndrive to replace this week. Would it be to my advantage to convert this to an open system. Can this be done and how hard is it to do? I checked the heat exchanger and it looks like new inside ( no blockage ) If the impeller in the lower unit is OK then I guess I should check the water pump impeller? Thanks for your suggestions
"No on the conversion.it`a a a
"No on the conversion.it`a a aluminum block that needs the closed cooling .impeller, thermostat, exaust riser are the principal culprits."
"Aluminum Block with IRON head
"Aluminum Block with IRON head! This combo need a steady temp, thats half the reason its being fresh water cooled. If the heat exch is good, next on the list is stern drive waterpump, then look for blockage in the exhaust elbow
Chris"
HAD THE SAME PROBLEM WAS A RET
HAD THE SAME PROBLEM WAS A RETURN HOSE TO THE OUTDRIVE THAT HAD A LOOSE CLAMP AND AT HIGH RPMS I WOULD LOOSE FLUID AND OVERHEAT
