200 Optimax
axel
"Pros and Cons of Jet Drive, W
"Pros and Cons of Jet Drive, What problems have you encountered? Would you reccomened this engine, what kind of bearing system?, Can it be run dry?"
"jet drive is a good system fo
"jet drive is a good system for shallow water.You lose a lot of power in the pump, hence more money for fuel.No not run dry as the waterpump needs water to cool itself and to prevent the impeller from damage."
