Results 1 to 2 of 2
Thread: Rusty engine
  1. #1
    Ron Brassord's Avatar
    Ron Brassord Guest
    Default " We recently acquired a 1988
    " We recently acquired a 1988 boat with an original Universal [Kubota] 3 cylinder engine. Although it has only 1300 hours and runs just fine, the engine has a terrible rust condition. Everything on it is effected. The engine space is dry and not exposed to bilge water but access is very limited without tearing apart the boat. There is no way to get at the rust to physically wire brush or scrape it for repainting.
    My question is, is there any product or process that will help the condition and maybe prolong the engine life?
    Ron Brassord Lighthouse Point Fl. "
  2. #2
    Join Date
    Jun 2003
    Location
    Posts
    127
    Default " Try OSPHO which can be purch
    " Try OSPHO which can be purchased at most hardware stores. This product is sprayed on to neutralize the rust. it is best however if you remove the large rust flakes first. Wipe and spray again if necessary. let dry completely for approx. 1 day and spray paint. Ospho will not allow the rust to continue spreading and will also etch the metal for the paint to adhere.
    thank you,
    Gabriel Acher - Dania Marine 1-954-927-2999 "
Similar Threads
  1. Rusty spark plug
    By sayed in forum Yamaha Outboard Forum
    Last Post: 04-08-2010, 09:05 PM
  2. Rusty velvet drive
    By jay presti in forum Pleasurecraft Marine PCM Forum
    Last Post: 01-30-2008, 07:24 PM
  3. Rusty ujoint
    By backfire101 in forum Volvo Penta Gas Archive
    Last Post: 12-26-2007, 11:43 AM
  4. b89 OMC 43 rusty pulleys
    By stratos1 in forum OMC Sterndrive and Inboard Archive
    Last Post: 09-23-2006, 06:02 AM
  5. Rusty Cylinder What next
    By R. Wood in forum Outboard motors archive 2000-2004
    Last Post: 07-02-2002, 11:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
