waynoharley
My trim will not go up nor dow
My trim will not go up nor down. Trim Motor runs when up or down button is pushed. Luckily the outdrive was in the up positions and I was able to trailer. I suspect fluid leak. Does any one now the procedure to check the fluid level and how to add the fluid and the capacity? I am able to move the outdrive slightly up and down manually. Thanks.
