Throttle control adjustment
buffman1
"I have a 1976 1150ELPT. The p
"I have a 1976 1150ELPT. The problem I'm having is with the control lever. When I push the lever over into forward gear it's just as its supposed to be. But then, I have to move the lever almost all the way to the bottom of its travel to increase the speed. Once I'm there it seems to be OK, i.e., I can attain full throttle. Anyone know why I might have such a huge gap of dead space in there? There is no cable movement on the engine end inside that dead space. Thanks, Jim"
"Jim, The OEM controls tend t
"Jim, The OEM controls tend to do that. You could also have worn parts inside the box. If you are getting full throttle (carbs full open), I suggest you live with it. Just think of all the arm extension exercise you are getting!"
