Results 1 to 7 of 7
  1. #1
    Join Date
    Aug 2006
    Location
    Indiana, PA, USA
    Posts
    28
    Default "My son looked in my tank but
    "My son looked in my tank but put sender on properly but wiring is wrong? It is circular and has 2 green wires, 1 red and 1 black ewire. The 2 green wires are mounted in the outer circle, red is attached in the middle, and the black wire is not currently attached. LM-1 is written on the unit or LW-1. Any ideas. Thanks Tank reads empty and doesn't move"
  2. #2
    Join Date
    May 2006
    Location
    pensacola, fl., u.s.a.
    Posts
    1,366
    Default "green wires are bonds. (g
    "green wires are bonds. (grounds) red wire (should be pink) is sender to guage. black is ground to guage. ground the black and it should work. if not, connect the red to the black. guage should peg. if not, trouble with wiring, or guage. if so, problem with sender."
  3. #3
    Join Date
    Aug 2006
    Location
    Indiana, PA, USA
    Posts
    28
    Default I connected the the black wire
    I connected the the black wire (which was unattached) to the same post as the pink wire and the tank reads full which it is. Is there a problem or is the sender reading accurate? The only lettering on the sender is KM-1
  4. #4
    Join Date
    May 2006
    Location
    Posts
    1,366
    Default "your guage, and wiring are ok
    "your guage, and wiring are ok. however, it will always read full wired as it is. connect the black to ground. (with green ones) leave red where it is."
  5. #5
    Join Date
    Aug 2006
    Location
    Indiana, PA, USA
    Posts
    28
    Default "Thanks Scott, I connected th
    "Thanks Scott,
    I connected the black wire to a screw on the outer ring. Still no reading. I finally pulled really hard on the pink wire and pulled it into the post and got a reading. The bad news. The tank is definitely full but reads only 1/3 full. Now what? I wish the nearest boat dealer wasn't 100 miles from me."
  6. #6
    Join Date
    May 2006
    Location
    Posts
    1,366
    Default "sender reads resistance. any
    "sender reads resistance. any corrosion will have an effect. you can try cleaning it, or order sender from this site for $20-25. measure depth of tank to get best fit."
  7. #7
    Join Date
    Sep 2007
    Location
    Whangerei New Zealand
    Posts
    1
    Default "be careful grounding the send
    "be careful grounding the sender to earth. if you have an aluminium tank it may cause electrolysis. better to earth the black wire back to the instrument panel, then you can be sure of a good earth."
Similar Threads
  1. Temperture sending unit
    By fitz647 in forum Mercury Mariner Outboard Archive
    Last Post: 04-09-2009, 08:06 PM
  2. Sending unit
    By spes in forum Miscellaneous marine engine topics
    Last Post: 02-08-2009, 06:36 AM
  3. THERMOSTATE SENDING UNIT
    By carlnap in forum Mercruiser Sterndrive Archive
    Last Post: 11-16-2007, 04:31 PM
  4. Fuel sending unit on the fritz
    By discobayken in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-26-2007, 11:14 AM
  5. OIL SENDING UNIT
    By John Colucci in forum Archive 2002-2006
    Last Post: 08-10-2002, 06:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
