buzzbait00
"I've got a 90 model Johns
"I've got a 90 model Johnson 120.Ok.I've been searching through here for an hour or so and think I have narrowed my problem doun to the vro fuel pump.If you pump the bulb it runs fine.If not it bucks up and doun and wont get on plain unless you start hitting the choke.Drained the tank,put new fuel in,removed the anti-siphon valve,pluged the vro side of pump,replace the fuel lines,filter and pick up tube.
Im thinking its the vro fuel pump.Sound right?How can you test a vro pump?If its the pump I've read on here were some say you CAN rebuild one and some say you CAN'T.So If you CAN!How do you do it?What parts and were can you get them?
THANKS,
Buzz!"
THANKS,
Buzz!"
