Click for Volvo Penta parts and manuals!
Results 1 to 4 of 4
Thread: Volvo AQ140A
  1. #1
    Default "I'm a newcomer to the sit
    "I'm a newcomer to the site. I have an AQ140A that the previous owner spent quite a bit of money on recently. The fly in the ointment is the cylinder head, which is cracked and (I assume) not repairable. Are replacement parts available? I have been reading in the archives and one point of view is that I would be throwing good money after bad and should repower. On the other hand, this is a boat for fairly light summer use. The boat is an '80s Sisu and I'm not sure that the expense of repowering makes sense. Does anyone have any advice?"
  2. #2
    Join Date
    Feb 2006
    Location
    Ladysmith, BC, Canada
    Posts
    5,862
    Default "You can go to an autowrecker
    "You can go to an autowrecker and get an automotive head from a B21 Volvo block. Specifically, from a 1976 to 1982 240 Volvo. However, you will have to keep your current camshaft, as an automotive camshaft will not work well on a marine engine."
    [URL]http://www.grandmaraismichigan.com/Recreation/fisherman.gif[/URL]
  3. #3
    Join Date
    Apr 2007
    Location
    Seattle, WA,
    Posts
    902
    Default First you may want to remove t
    First you may want to remove the head to make sure it's not just a bad headgasket. That's a fairly cheap and easy fix compared to the alternative.
    Another reason to keep the camshaft is because VP wants roughly $800 for a new one. Ouch! There is a guy a few posts down from this selling an AQ140 maybe he will seperate the head for you.
  4. #4
    Join Date
    Jul 2006
    Location
    Qualicum Beach, BC, Canada
    Posts
    341
    Default "I crack a head a few years ag
    "I crack a head a few years ago, at the rear corner. I had it welded and it has worked fine ever since. I questioned a marine mechanic about the reliability of a welded head and he said that if it was done properly it would be as good as new. So far so good.
    Tom"
Similar Threads
  1. Aq140a
    By dusher in forum Volvo Penta Gas Engine Forum
    Last Post: 10-24-2009, 05:29 AM
  2. Volvo aq140a carbs
    Last Post: 10-23-2009, 09:13 AM
  3. Repower Volvo AQ140A or new carb
    By mike_s in forum Volvo Penta Gas Archive
    Last Post: 07-23-2009, 01:09 AM
  4. Volvo Penta Parts AQ140A
    By fury in forum Volvo Penta Gas Archive
    Last Post: 06-25-2007, 08:50 PM
  5. Aq140a
    By kiwiguy in forum Volvo Penta Gas Archive
    Last Post: 03-07-2007, 01:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
