Strange electrical problem possible gremlins
switlikbob
"Okay, here we go. When I hav
"Okay, here we go. When I have my alternator hooked up to the positive lead (GM 1 wire alternator) on one of the 2 batteries in my boat, and the boat is running, I get water temp reading of 180-200 degrees. As soon as I pull the alternator wire off the alternator (with the engine still running), the water temp gauge reads 20 degrees lower. Do I have some sort of wire resistance problem here?"
"engine going = 14.4 volts
wi
without alt conected 12.6 volts
therefore meters not reading proper temperatures as there is no volage regulater as in car dash meters, so as your voltage varies so does the reading you get.
also do not run the alternater without being conect to the battery load could damage the unit"
"Thanks for the reply. my nex
"Thanks for the reply. my next question is:
Where do I get a voltage regulator for my gauge cluster?
Also, why does this voltage spike only affect the water temp gauge and not the others?"
