"1988 454 Crusaders about 1100
"1988 454 Crusaders about 1100hrs, what is the proper oil pressure? I have been using staraight 40 weight as recommended by the manual. At idle get 10-20 psi and at 3000 rpm get 35-40 on Port and 40-45 on starboard. Thinking the Port numbers are a little low? or am I ok?
What is the proper oil pressure at 3000 rpm? Should I switch to 30 weight? Would the lower viscosity "raise " the pressure some?"
