C
chris szymanski
Guest
I have a old 90hp 89 modle vro
I have a old 90hp 89 modle vro and am in the process of changing the lower leg gear oil. I drained the leg oil by removing the largish screw from the bottom of the leg near the skeg. Now I'm not sure how much oil to put back into the leg. There is a phillips head screw near the water intake and another largeish flat headed screw like the one used to drain the oil near the cavitation plate. Both seem to lead into the lower leg gear oil chamber. Do I fill all the way up to the screw near the cavitation plate or only as far and the phillips head screw near the water intake? Why are there two screws anyway? Thank in advance.
Chris
Chris
