Looking for exhaust check valves 350Q
stephan
" I'm looking for, what I
" I'm looking for, what I want to call, Exhaust check valves. 1972 Chris Craft 350Q. These are at the top of exhaust elbow's that fresh water hoses go to from the heat exchanger.
The housing for these have three bolt holes. The "check valves" are rusted shut on the Port engine and Starboard engine will not close causing exhaust to flow back into the fresh water system (heat exchanger).
Stephan "
" i had the same problem on my
" i had the same problem on my 1967cc,they will pop out to clean them .i used a tooth brush and noxon brass cleaner,now they work perfectly . "
They are way beyond that now.
They are way beyond that now. One of them I tryed to pop out and damaged it. The others look rotted..
Any other suggestions for new ones.
Stephan
" Hello Stephan.
The pressu
" Hello Stephan.
The pressure relief valves you are looking for are only available through Chris Craft. I can usually get them, but dont have any now. Call Earl Stilson Marine at (586)-468-0937 and ask for part # 16.99-07346. If there are any other parts you may need or information please dont hesitate to call me at 1-800-748-7739 or 954-927-2999
Thank you,
Gabriel Acher - Dania Marine Corp. - Florida "
