bill_jensen
Hi mine wont idle. it seams l
Hi mine wont idle. it seams like it is getting to much fuel with the muffs on it idles good but if I put it in water it will not idle below 1500 rpm it runs great at speed gets out of the hole well full throttle about 55 or 5300rpm compression is good 150 in all clys I have rebilt all the carb new seats ajusted floats to spec new plugs if I reve it up in neutral it will idle for a few sec but then it will die out tryed larger air jets if I tilt it up it runs a little better if I turn off the gas be for it dies it starts to run better
Thanks Bill
Thanks Bill
