Click for Volvo Penta parts and manuals!
Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2007
    Location
    thomasville, nc, usa
    Posts
    2
    Default "I have a 1976 dixie classic w
    "I have a 1976 dixie classic with a volvo penta 280 outdrive. My battery was ripped from the boat, leaving me with wires that need to be repaired. Unfortunatly, the motor is in the down position and can't be towed. How can I manually tilt the motor so I can get it to the shop? HELP!!!!!
  2. #2
    Join Date
    May 2006
    Location
    pensacola, fl., u.s.a.
    Posts
    1,366
    Default "ask the shop if you can borro
    "ask the shop if you can borrow their trailering clip to hold it up. if not, use a 2x4, or similar. release the reverse lock by pulling down, and it will lift easily. BE CAREFULL. it is heavy. keep hands out of the way. also can damage drive if dropped."
  3. #3
    Default "If a 280 is anything like a 2
    "If a 280 is anything like a 275, there's a little 12VDC motor that lowers and raises the lower unit. I blew a fuse on my tilt circuit at the lake last month and just jumpered the motor directly to the battery to raise and lower it so I could get back on the trailer and back home. One polarity raises and reverse polarity lowers."
Similar Threads
  1. How do you manually trim up a motor if you trim motor goes
    By paul_burgoon in forum Mercury Mariner Outboard Forum
    Last Post: 05-29-2017, 08:51 PM
  2. Motor wonbt trim down Even manually
    By big_builder in forum Johnson Evinrude Outboard Archive
    Last Post: 07-15-2008, 05:38 PM
  3. How to manually tilt 1997 yamaha 40 hp
    By Jane in forum Yamaha Outboard Archive
    Last Post: 07-25-2007, 11:01 AM
  4. JWBmarineTHANKSWhere would it be to do manually
    By mamasplace in forum Johnson Evinrude Outboard Archive
    Last Post: 05-28-2007, 10:29 PM
  5. Manually Turn over 30L
    By russ0943 in forum Mercruiser Sterndrive Archive
    Last Post: 05-25-2006, 04:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
