Well I got this boat and had 2
Well I got this boat and had 2 good days on the water when I get a noise in the valve cover. I open the cap and can see that the first rocker arm isn’t moving and the push rod is bouncing up and down. Pull head and find a broken lifter. Pull the lifter and find that the camshaft is all chewed up from lifter. So no big deal I’ve replaced camshafts before figure I will just replace.
First I cant find timing gears anywhere which I wanted to change knowing that I was going to remove them anyway and then find that the camshaft is $ 814 .
Can anyone help me on getting parts for a better price or should I just get rid of the boat and find something else. It is an older boat with an AQ 130 C motor. I know I will find other things that need fixing which is fine but is it worth it if these parts cost so much?
