Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 3 of 3
  1. #1
    Default "I didnt have tilt/trim so i b
    "I didnt have tilt/trim so i bought a trim motor and im having trouble installing.The motor has a blue and green wire.And the switch has blue,green and red wire.The guy that sold it to me said that the red was positive blue was for up,and green for down.He told me to run red wire from the switch to pos terminal,green to green and blue to blue then ground them.Does that meen ground to neg trem or just to metal.Because i grounded to neg trem and push button it started getting real hot an melt wire,when i grounded to metal nothing happend at all.To see if motor worked i put blue on pos green on neg, motor went up then vise versa motor went down. So please help by explaining how to hookup. Thanks"
  2. #2
    Join Date
    May 2006
    Location
    pensacola, fl., u.s.a.
    Posts
    1,366
    Default "switch wiring is red- power t
    "switch wiring is red- power to switch. green- power from switch-down. blue- power from switch-up. switch does not connect directly to two wire trim motor. motor works by reversing polarity. this is accomplished with relays, or solenoids. a little too complicated to explain here. you will need a book with wiring diagram. sounds like you are missing something."
  3. #3
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    Default i need year and hp and i can s
    i need year and hp and i can send u drawing
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
Similar Threads
  1. Trim switch not working 1999 305
    By shawns99 in forum Mercruiser Sterndrive Forum
    Last Post: 06-13-2010, 02:07 AM
  2. Tilt and trim switch
    By slipknotsteve in forum Johnson Evinrude Outboard Archive
    Last Post: 07-07-2008, 10:12 AM
  3. Trim switch #
    By bradboat in forum Johnson Evinrude Outboard Archive
    Last Post: 06-13-2008, 12:50 PM
  4. Trim indicator switch
    By pjsomers2 in forum Volvo Penta Gas Archive
    Last Post: 09-05-2007, 04:08 PM
  5. 1978 Trim Switch
    By bassmoe in forum Johnson Evinrude Outboard Archive
    Last Post: 05-12-2007, 09:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
