MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 7 of 7
  1. #1
    Join Date
    Jan 2007
    Location
    liverpool, merseyside, uk
    Posts
    3
    Default Hi I have a mercury 1980 50hp
    Hi I have a mercury 1980 50hp mercury that cuts out and wont idle the engine just cuts out has to be on high revs and then its fine. I have cleaned the carbs but still wont tick over Any help or ideas .gordon
  2. #2
    Join Date
    Nov 2005
    Location
    , il,
    Posts
    2,198
    Default "compression and spark test fi
    "compression and spark test first, you can use a timing light to see if it has spark on each cyl. also it could be a carb flooding, with engine off pump bulb and look down carbs to see if any fuel is dripping out."
  3. #3
    Join Date
    Jan 2007
    Location
    Posts
    3
    Default Cheers JB
    Cheers JB
  4. #4
    Join Date
    Jan 2007
    Location
    Posts
    3
    Default Hi New to boat maitainence but
    Hi New to boat maitainence but how do you know if the float is stuck closed or jammed open and how can you tell if they need replacing.
    Gordon
  5. #5
    Join Date
    Nov 2005
    Location
    , il,
    Posts
    2,198
    Default "closed means no fuel to carb,
    "closed means no fuel to carb, open means fuel runs thru carb when running or pumping the bulb. if your boat has sat for more than a year it needs the carbs removed and cleaned, and each jet cleaned and verified to be open.
    http://www.themarinedoctor.com/cgi-b...num=1179778624
    link for carb cleaning"
  6. #6
    Join Date
    Nov 2005
    Location
    , il,
    Posts
    2,198
    Default "another vidio [url=""]http
  7. #7
    James d's Avatar
    James d Guest
    Default "I have a 2004 Mercury 50 Hp m
    "I have a 2004 Mercury 50 Hp motor. Ran weel last time out ,about three weeks ago. Will not start now. No spark to any plug. Ideas?"
Similar Threads
  1. wont idle 2004 3.0
    By jerni21 in forum Volvo Penta Gas Engine Forum
    Last Post: 08-18-2010, 06:41 PM
  2. Wont idle
    By sidebottom in forum Mercury Mariner Outboard Archive
    Last Post: 09-21-2009, 05:29 PM
  3. 1996 Mercury 115 Wont Idle
    By chevy406 in forum Mercury Mariner Outboard Archive
    Last Post: 06-28-2009, 10:08 PM
  4. Wont start in water wont idle just wont go for me
    By Brook Kinsela in forum Mercury Mariner Outboard Archive
    Last Post: 03-26-2007, 10:20 AM
  5. Mercury 70 hp misses and wont idle
    By randy_h in forum Mercury Mariner Outboard Archive
    Last Post: 03-11-2007, 02:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
