"Hello fellow mariners. My que
"Hello fellow mariners. My question is,when my motor is in the tank, it runs well but it seems to stop pumping for a seckond or to. If I rev it up a bit it pumps well. I have replaced the water pump, housing,gromet,and the base plate.All apears normal but the sides of the block are exceptionally hot.The temperature of the outcoming water matches the side of the block. I sould mention that I put a carb kit into it and it runs well, but if I open the couling, the rpm will raise. Seams as if it is running rich or not getting enough air with the cowling closed.Compression on both cylinders is 160-165lbs I have this motor in a tank and am feeding it 87 outane. Any suggestions the motor is a 1957 Evinrude 18 hp fastwin.Ken 25/1 oil mixture"
